406 GLX computer/radio display
x 1240
Unread post by Peter.N. »
The display on mine is variable, sometimes you can read it others it has sections missing, I have seen one or two on ebay but don't know if the radio/clock only type will work with the computer. Can anyone help?
spider
x 77
Re: 406 GLX computer/radio display
Unread post by spider »
If I remember correctly there's three bulbs in it. Look carefully with a torch to ensure its working just not lit up ? :)
Andy.
x 1240
Hi Andy
Its working OK but there are lines of pixels missing but not always the same ones, it seems to be temperature dependant but doesn't always behave the same in a given temperature.
spider
x 77
Is this for the 01 plate ?
I can have a look but I think my tech data stops (reliably) at about 99 for these.
I'll try later though for you.
Andy.
x 1240
Yep, that's the one. Thanks
spider
x 77
Um, that was not as straightforward as I'd expected. Anyway:
There's a variation depending if its navigation or not. See pics (please read description on top right of pics carefully) :
I'm not sure which yours is though, probably one of the second picture's ones...
Not sure if its any help Peter. :)
EDIT... I'm not running IE6 :D , that's Win 2K running in a VM...
Andy.
x 1240
I make mine 6563 31 black with satnav. Thanks Andy.
spider
x 77
So you'd have to (as you suspected) obtain the correct one. You may find one in a scrapyard hunt, you never know.
I'd dread to think how much they are new, given that (If I remember correctly) a 206 basic one without navigation was about £130 five years ago...
Andy.
x 1240
I rarely consider new parts for my cars, two or three would be more than I paid for the car :shock:
spider
x 77
:D I was just saying the cost would be um "high" from the main dealer to say the least.
Andy.
