97 R TD BOSCH PUMP?
chrisjvm
97 R TD BOSCH PUMP?
Unread post by chrisjvm »
Hello Citroenists.
I was wondering....
Does a 1997 Xantia TD have a Bosch diesel pump ?
Regards
'09 Citroen C5 3.0 hdi Tourer.
'15 Peugeot 308 1.6 bluehdi SW.
'89 VW T25 Westfalia California.
'01 BMW 530i auto.
x 1240
Re: 97 R TD BOSCH PUMP?
Unread post by Peter.N. »
Sticking my kneck out I would say probably not, unless it was registered late.
spider
x 77
Unread post by spider »
If its any help:
If it was a 406 then its 99% certain it would have a Bosch pump, however the Xantia earlier models did not have an electronic advance as far as I know whereas all 406's did.
Andy.
chrisjvm
Thanks for the replies....
The reason I asked was because I wanted to know if i could run it on Veg oil....
And I was under the impression that a Bosch pump was the only one that would be compatible ??
'01 BMW 530i auto.
spider
x 77
A Lucas unit won't be up to the job really, or won't last very long.
Andy.
chrisjvm
Oh ok.... Thanks Andy...So its likely to be a Lucas pump which is a no no re veg oil :cry:
'01 BMW 530i auto.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
I'd have thought a 97 Xantia would have a Bosch pump, mine which was built in 96 and has electronic advance does, best to take a look at the pump to make sure.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
ALL 1.9 TD XUD engines had Bosch Pumps... I ve NEVER seen a TD lump in a Xantia without..
Only 1.9 N/a SD were lucas mechanical, and the 2.1 was Epic...
So go for it!
A very sad...
1994 XM 2.1 d auto
chrisjvm
Thank you all gents...
I will go for it citroenxm! I appreciate
You clearing up the ambiguity.
Regards
'01 BMW 530i auto.
citroenxm
Fallen Hero
x 70
You can tell a Bosch Pump.. they sit high in front of the engine and complete obscure the the Hearter Plug and water pipe to the top of the head on the cam belt side (left side of the head) Theres also a Curcular "Mushroom" sort of device that has a black pipe comming out the side of it to the Air intake Pipes over the top of the engine
The lucas pump a a lower profile type pump, and leans forward a bit more, and has better access to the heater plug forementioned....
But, if it lucas, its been stupidly converted to it, or its the First One EVER I will have seen, If it is lucas.. I have pleanty of Bosch Pumps and injectors, a set just removed from a car Im in the middle of scrapping...
Ive got 4 Xantias with Bosch pumps to sell.... 1 estate and 3 hatchs...
A very sad...
1994 XM 2.1 d auto
chrisjvm
Fingers crossed then citroenxm
I really appreciate your advice.
Regards
'01 BMW 530i auto.
spider
x 77
Apart from a 306 where older shape TD's were Bosch and the newer shape ones were 90% Lucas for some odd reason. :) Interestingly the NA 1.9 later shapes were all Bosch...
Andy.
Old-Guy
x 32
Unread post by Old-Guy »
citroenxm wrote:You can tell a Bosch Pump.. theres also a Curcular "Mushroom" sort of device that has a black pipe coming out the side of it to the Air intake Pipes over the top of the engine.
Reminds me more of the Starship Enterprise in shape - it's the boost pressure compensator, increases the amount of fuel injected according to the intake boost pressure. The little black pipe commonly splits on the underside resulting in under-fuelling and loss of performance. Tell tale is oil mist over the intake pipe where it joins the inlet manifold.
redzzed
Unread post by redzzed »
I have a 1996 xantia td with a bosch and it runs fine on veg oil .
if you are thinking of using filtered veg oil u will need to monitor/change the fuel filter regularly ,which is easily done .
bearing in mind that veg oil loses viscousity in cold weather and the engine will not start happily anywhere around freezing or below.
In cold weather u can probably get away with 65/35 %diesil/veg, but do make sure from others first .
lucas pumps cant handle it , and will fail before too long , whatever the temprerature .
current : 1997 xantia 1.9 td sx a/c
previous cars :
1997 zx memphis td
1996 zx volcane td
1994 zx volcane td
citroenxm
Fallen Hero
x 70
As said, from what Ive seen, so far EVERY single Xantia TD I have seen has had a Bosch on it... And beleve me, Ive seen a few!! As weel as my own!
And as mentioned, Ive 4 to sell on too!!! All with Bosch
A very sad...
1994 XM 2.1 d auto
