on my 1.9 td. Every time i fill it up. To the have way mark. A couple of miles down the road. It goes back to the seconded before the reserve line.
If you know what i mean.
Have i got a problem. Or is it the same to otherd.
Does your needles seem to have a weird pattern
xantia fuel needle
- x 8378
Re: xantia fuel needle
Most Xantia fuel gauges seem to be a bit non-linear although yours sounds more so than normal.
I'd suspect the tank sender unit has a bit of an issue but to be honest I'd not worry too much about it. Learn how many miles you can do for a given amount of fuel and watch the trip recorder rather than the gauge...
Those of us who run LPG tend to do that by habit because the LPG gauge is wildly inaccurate at the best of times...
DickieG
- Monaco's youngest playboy
- x 38
Duff sender unit, been there had that on my Activa.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8378
It's still as good as gold RichardDickieG wrote:Duff sender unit, been there had that on my Activa.
DickieG
- x 38
Ah good to hear the replacement is a goodun, I recall the neelde falling very quickly on my first drive home and wondering whether it had a fuel leak or Activa fuel consumption was even worse than its reputationCitroJim wrote:It's still as good as gold RichardDickieG wrote:Duff sender unit, been there had that on my Activa.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8378
It's bad enough Richard and using the Activa more these days I notice it. I can see why my XM was converted to gas. It makes great sense when running a TCT!DickieG wrote:Activa fuel consumption was even worse than its reputation
jacksun1987
Well the light still comes on. Be funny if i have loads of fuel and i not know about it
citroenxm
- Fallen Hero
- x 70
Well there IS also another part that fails that EVERY one seems to forget.
If you do change the sender and its still the same, it WONT be the guage, but if you remove the instruments, take the front plastic off remove the speedo theres a small "Daughter Board" fitted behind there... And it is actually this board that converts the level sender signal to the guage signal.. The guage and Level senders are NOT directly connected as many beleve they are.
Change this small board and there you are.
I only know this as an owner had a P reg 1.8 petrol, and he swapped the tank unit twice and still had a fault, I swapped the guage, the same. Then I stuided the "Tracks" on the back of the speedo unit and discovered the small board. Swapped it from another and its been fine ever since for the last 3 years.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
