Killing traffic master.
xenton
Please tell me this can be done easily via lexia? Due to my HPi fault I have to switch the ignition off and immediately back on to get the car out of limp home mode and every time I do this traffic master starts shouting at me, usually just hitting the traffic master button shuts it up, but for some reason, occasionally it causes it to start the message from the beginning, and there is nothing to do but sit through it.
Mark D.
2001 C5 2.0 HPi exec.
oneday
Re: Killing traffic master.
cant remember seeing any option for disabling the dam thing i did have a quick look but nothing found yet
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
lurchy666
nope no lexia option to kill her, best way is to find her box (behind glove box) and open it up then with a multi meter test for the 12 volt lives and push all the pins out of the connector (only the lives or you lose your speakers), then plug it back in and see if all your speakers work, then you get to do away with the switch as well
c5 2.2 auto hdi estate 52 reg
- x 2941
You can switch it into 'manual mode' by pressing the button twice quickly, it won't then interupt the music with traffic messages.
xenton
Thanks ill give that a go.Gibbo2286 wrote:You can switch it into 'manual mode' by pressing the button twice quickly, it won't then interupt the music with traffic messages.
Mark D.
xenton
Thanks, if it still shouts at me after trying manual mode I'll try that.lurchy666 wrote:nope no lexia option to kill her, best way is to find her box (behind glove box) and open it up then with a multi meter test for the 12 volt lives and push all the pins out of the connector (only the lives or you lose your speakers), then plug it back in and see if all your speakers work, then you get to do away with the switch as well
Mark D.
Xaccers
- x 188
I think manual mode only stops it giving traffic reports as it gets them, which it will only do if you activate the subscription.
The shouting about renewing it when you quickly restart the car is different.
DIY sphere tool
DIY sphere tool
citroenxm
- Fallen Hero
- x 70
On the Xantias, the buttton is so big, if you wedge it in with a coin that shuts the cow up! and the radio still works...
Opening the TM box up could interupt the loud speakers for the radio as mentioned above...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
reblack68
I can confirm that killing the power to the box shuts it up forever and does not affect the speakers, I've done it on a Xantia and two C5s.
Richard
Care of a 1994 205 D.
citroenxm
- Fallen Hero
- x 70
Just power cables? which wires are those then...
ive tried plug unplugging and that doesn't work...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
lurchy666
basically open the box up and get your multi meter set on volts and pull all the pins which are live so the dont connect any more, leave all the others so youve still got speakers
citroenxm
- Fallen Hero
- x 70
Fantastic! Thats great... thanks
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
