Removing Xantia mk2 petrol engine
atr
x 6
Unread post by atr »
Hi
I want to remove the engine from my 2001 2.0 16v (RFV) Xantia. I would like to learn from your experience if it can be done without the transmission and will appreciate any advice about it.
let me point out that I've done it on several vehicles that I've ownd before, but not on Xantia, so that I'm not a complete novice.
Thanx.
x 94
Re: Removing Xantia mk2 petrol engine
Unread post by citronut »
i have never tried this but would think the easiest route would be drop the lot out in one unit, as i would think it is going to be far easier to split the box from the engine on the floor
Regards, malcolm.
x 8436
Precisely right Malcolm. It has to come out through the top as one unit...
handyman
Unread post by handyman »
You can take the engine/gearbox unit out through the front as well, but it do involve removing the slam panel, lights, radiator.......... :roll:
H
x 8436
It's a good idea to remove the rad in any case as it saves damaging it...
spider
x 77
Unread post by spider »
Agree with rad removal first if possible, failing that a sheet of plywood (cardboard not really up to the job when you have something swing around it will go though that like it was not there!) will help protect it a little bit.
Andy.
x 8436
Exactly Andy :( I have ruined a perfectly good rad in removing an engine that took an unfortunate swing!
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Despite the looks of it, and it looks like theres room they do NOT go downwards.. But I also agree, the whole lot needs to come upwards and at an angle in which the gearbox is lower then the engine, so it clear's the chassis ...
A very sad...
1994 XM 2.1 d auto
andmcit
x 30
Unread post by andmcit »
Don't expect the lot to wheel forwards out were the front end completely removed
as the cross member under the rad will scupper any idea of wheeling it on a jack so
a hoist would be needed - if that's the case just lift the lot out in one piece from the
top. Whilst the engine can be left in situ where a gearbox is drawn out through the
wheelarch the opposite can't be done leaving the gearbox with just the engine out.
As Paul says, a tilt on the lot helps unhook the gearbox out after the engine clears.
Nothing moves you like a Citroën
