Hi
I know this has been discussed endless times before but I just wonder if this one has been checked before
http://archiv.ravenol.de/products?part=321" onclick="window.open(this.href);return false;
Regards
Zohar
Ravenol ATF for AL4
lancia58
- x 8
Ravenol ATF for AL4
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 8422
Re: Ravenol ATF for AL4
On the face of it that looks good Zohar...
My last check would be to cross-reference to the official ZF spec. The list of transmissions are only those that use LT.
I may have to modify my signature
lancia58
- x 8
Hi Jim
Where can be found the official ZF spec ? It is half the price of the LT
Regards
Zohar
Regards
Zohar
- x 8422
You can find the ZF ATF Specs. here Zohar..
The Ravenol stuff is apparantly good for the AL4 and 4HP20 as it complies to ZF specification S671 090 170 which cross-references to the ZF document above..
Good find, excellent
Is Ravenol ATF available in the UK though?
lancia58
- x 8
Hi Jim
Below is a link to the UK office
http://www.ravenol.co.uk/" onclick="window.open(this.href);return false;
Regards
Zohar
Regards
Zohar
lancia58
- x 8
Below is the link to the UK online shop
http://ravenol-shop.co.uk/shop/category ... =cid%3D%26" onclick="window.open(this.href);return false;
Regards
Zohar
Regards
Zohar
- x 8422
Mandrake
- x 695
Err, unless I'm going blind, that's £1 a litre more than I paid for the genuine Mobil LT71141 from opie oils ? Why bother ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
lancia58
- x 8
Hi
Here you have 8 liters for €56 + €15 shipping. That is around £7.4 per liter.
http://www.ebay.de/itm/8-Liter-Getriebe ... 1957000%26" onclick="window.open(this.href);return false;
Regards
Zohar
Regards
Zohar
Mandrake
- x 695
Stumbled across this and thought you might get a giggle out of it Jim:
https://s3.amazonaws.com/drbritt/SuperS ... ic+ATF.pdf" onclick="window.open(this.href);return false;
Apparently this "Supersyn universal synthetic ATF" is suitable not only as an LT71141 replacement (ZF 4HP20 specifically listed as compatible) but it is also suitable for cars requiring Dexron II and Dexron III.
One fluid that will replace three mutually incompatible fluids ? I don't think so somehow.
Buyer beware believing the spec sheets on non original oil types! Some companies will put anything on the label to get you to buy their stuff, knowing that gearbox failures a few years later probably won't be traced back to them so they can get away with it...
Simon
1978 CX 2400
1978 CX 2400
