HID Lights - retro - fit MOT advice
brittleware
Unread post by brittleware »
As I'm about to fit some HID lights to our Eurovan I checked the latest MOT bulletin - I quote:
"Due to the adverse affect on the beam pattern, it is not considered legal to convert conventional halogen headlamps to HID
xenon using the existing lens and reflector. Fitment of complete HID xenon headlamps is permitted, although the lamp
may still be required to have some form of self levelling system to be legal. In either case, there are currently no
Reasons for Rejection in respect of MOTORCYCLE HID headlamps, providing, of course, that the headlamp aim requirements are met."
How does this relate to CAR headlights? Anybody?
Citroen 2cv
Citroen 2.5 Safari
Citroen XM 3.0 V6
Citroen XM 2.0 turbo
Fiat Ulysse 2.2Hdi
neil123
Re: HID Lights - retro - fit MOT advice
Unread post by neil123 »
may still be required to have some form of self levelling system to be legal."
Er...Does that help?
Deanxm
x 87
Unread post by Deanxm »
No vehicle is exempt, any HID Xenon burner must be housed in a reflector designed to be used with it, ie projector lamps, they must be self leveling and they must have headlamp washers.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Chlorate
Unread post by Chlorate »
They're quite illegal to fit into standard housings in a lot of places, special HID lenses are a must I'm afraid. If you've ever been stuck with some b*stard with illegal after market HIDs behind you at night it's obvious as to why.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
GB
Unread post by GB »
Road Traffic Act 1988 (RTA) Road Vehicles Lighting Regulations 1989 (RVLR) covers the technical lighting requirements for all vehicles on UK roads. Section 42 of the RTA makes it an offence to contravene any regulations made under section 41: using a vehicle with lighting that doesn't meet the RVLR requirements is an offence with a maximum penalty of £1000.
Aftermarket HID conversion kits do NOT meet the requirements of RVLR in several respects, eg. headlamps must be fitted with the light source for which they are intended - halogen headlamp with halogen bulb, and HID lamp with HID bulb only (E-type approval).
05 C5 VTR 2.0 HDI
115k
brittleware
neil123 wrote:How does this relate to CAR headlights? Anybody?
Well... the headlamps on our C8 clone (Fiat Ulysse) are ALL projector types. There's seemingly no difference in the projector
assembly between H7 Xenon and H7 tungsten.
There's also an interesting dichotomy in the piece of legislation you quote:
"may still be required"?
Whatever, I'll fit 'em and see.
Citroen 2cv
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
brittleware
(That info about the projector lights gained via Fiat Eper. Prices range between an absurd £220 to a fantastic £749. No wonder scrappies are in business!)
Citroen 2cv
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
lurchy666
Unread post by lurchy666 »
Basically I was told by my mot bloke when I was there with the xantia ( as I was considering hids in the xantia) unless the car has projector headlamps, self leveling suspension or headlamps and headlight washer ystem they wouldnt pass an mot
c5 2.2 auto hdi estate 52 reg
Deanxm
x 87
Thats right, self leveling must be built into either the light unit itself or into the cars suspension system, so a hydraulic citroen does not need leveling light units.
D
XM Prestige PRV6 92
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Well my C5 has hydraulic suspension plus the factory fitted xenon headlight option and the headlights are also self levelling.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Deanxm
x 87
yes but there is no legal requirement for it or need really, prob a leftover from the conventionaly sprung version?
D
XM Prestige PRV6 92
kentc5
Unread post by kentc5 »
Well the 1st gen C5 that have Xenon's also have self leveling lights as well as the suspension.
I was told by a dew MOT places some friends work in that lights have to be self leveling / washing system and correct pattern layout.
I must admit I did not know that the self leveling suspension can replace the self leveling lights ... as it does take a while to adjust as the self leveling lights are much quicker to respond.
Current Cars:
Citroen Xantia 3.0 V6 Exclusive ('98)
Alfa Romeo 166 2.0TS ('03)
Audi A6 C6 2.4 V6 SE ('05)
BMW 735i Individual M-Pack ('00)
Lexus GS300SE Navigator ('98)
Toyota Prius T-Spirit ('04)
x 3296
I beleive that the self levelling requirement is there to make sure the lights are pointing at the correct attitude. A normally sprung vehicle with a heavy load in the back would (obviously) have the nose pointing upwards in relationship to the same car empty. When I had a Skoda Octavia with these lights, it would adjust them with the load balance in mind. As a Citroen with hydraulic suspension makes the adjustment for the whole car, the lights will be aimed correctly.
DickieG
x 33
Hell Razor5543 wrote:When I had a Skoda Octavia with these lights, it would adjust them with the load balance in mind.
Factory xenon headlights adjust their height pretty much instantly and always maintain the correct headlight height during use.
Hell Razor5543 wrote:As a Citroen with hydraulic suspension makes the adjustment for the whole car, the lights will be aimed correctly.
Citroen suspension height adjustment happens very slowly with a fair degree of delay which makes me wonder whether to comply with regulations the lights themselves need to have automatic height adjustment.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Deanxm
x 87
Vosa states self leveling air/hydraulic suspension is acceptable for compensating headlamp allignment due to loads added to the vehicle so im not sure why citroen use both, maybe all xenon units are produced self leveling regardless, maybe citroen were planning on ditching hydraulics when the C51 was concieved and were being prepared, would be interesting to know why they done it anyway.
D
XM Prestige PRV6 92
