Hi all, my steering wheel has come loose and you can move it up and down and left and right, it is locked into place and the nut is tight! It moves about a 1cm in all directions!
Any suggestions guys?
Cheers, Chris.
Xantia Steering Column Loose
cc101
Xantia 1.9 TD 1993 (sinker)
mirafioriman
Re: Xantia Steering Column Loose
Top column bearing? I seem to recall my car had this replaced by the previous owner before I bought it.
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
gadgetgricey
Yeah, my old L reg did the same. Top column bearing.
Whip the steering wheel off, and you might even be able to knock it back down onto the shaft, problem solved.
Cheers
- Dave -
Cheers
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
cc101
Cheers guys I'll take a look at that tomorrow.
Chris.
Chris.
- x 8417
Yep, that'll be it Chris. It causes some MOT testers a good deal of teeth sucking... The easiest way to fix it is to get another steering column from a scrapper.
It's not easy to fix in-situ as the bearing is crimped into the top of the column and I'm not sure if it's available as a spare part on its own.
cc101
Fixed it, tapped the bearing back into place and all is well!
Cheers all, Chris.
Cheers all, Chris.
- x 8417
Oh excellent Chriscc101 wrote:Fixed it, tapped the bearing back into place and all is well!
Cheers all, Chris.
