Hi All,
Fixed my exhaust recently and it is not sealing with the paste I've got.
Anybody got any suggestions ?
Kenny
Exhaust assembly paste
KennyW
- x 165
C3 1.4 petrol (SWMBO)
- x 1492
Re: Exhaust assembly paste
Kenny
I generally use Holts Exhaust Assembly paste - what are you using, and where it is leaking? The flange type ones normally seal dry, and the one on the back of the engine should have a 'brillo pad' type seal in it.
- x 8417
I've got some Bosal stuff. Seems the best I've used so far...
- x 94
and if its a car with a CAT you must not use any jointing compound forwards of the CAT
Regards, malcolm.
Deanxm
- x 87
The bosal stuff that goes in the mastic gun is the pups nuts, it will actualy glue the joint together as well as seal it, there is no better stuff out there imo.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Lighty
- x 34
GSF offer this week, is 5 tubes and a gun for £9.99 + vat
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 8417
Is that in case the paste does not do the job and your frustration with a leaky exhaust just becomes too much to bear?Lighty wrote:and a gun for £9.99 + vat
Of course a proper exhaust properly fitted never needs paste.
- x 8417
And rocking horse poo is very freely available....Gibbo2286 wrote:Of course a proper exhaust properly fitted never needs paste.
KennyW
- x 165
Thanks for all the replies,
Bosal it is then.
I used a tube of paste I had in my garage can't remember the name.
Richard, It is the flange joint after the Cat which is vibrating, loosing off and causing a rattle. It's pain in the !!!!
I'll see if I can use my friends ramp at his garage it will make life easier.
I never had a problem in the past with any exhaust I've fitted including the Xantia TD.
Kenny
Bosal it is then.
Kenny
- x 94
have you got the correct clamp on as it should be a stainless steel one piece band type flange clamp both ends of the CAT
here is BOSAL's online cataloug
http://www.catalogue.bosal.com/pages/ex ... del=Xantia" onclick="window.open(this.href);return false;
Regards, malcolm.
KennyW
- x 165
Malcolm ,
Yes, I believe so as it fits the pipe diameter.
The exhaust came with all the clamps as part of the package and matched the old ones I removed.
Kenny
Kenny
