307 2.0 Hdi Abs fault
nealy 1572
Unread post by nealy 1572 »
Hi all new to peugeot. Ive just got 2002 307 hdi 2.0 and abs module not working previous owner changed it but i dont think he fitted like for like numbers i was wondering if there was any way of finding out correct number for model or is there a way to dit 1 with different numbers.
Im sorry if been asked before but any help appreciated.
spider
x 77
Re: 307 2.0 Hdi Abs fault
Unread post by spider »
Hello.
It will need to go onto a Planet diag or Lexia at a push to be coded in at a minimum, it may not accept a different unit but the diag will at least allow the BSi (the 'system computer' the 307 is controlled by in effect) to be told about the replacement unit.
Andy.
nealy 1572
is there a way to find out which part number was already fitted as car is due for mot shortly and i need to find a solution if at all possible
spider
x 77
You may be able to find out from servicebox.
http://public.servicebox.peugeot.com/" onclick="window.open(this.href);return false;
Register and use that with your RP / Vin number to locate the part number. It should be free, the wiring diagram sections etc are paid but the part sections are usually free. If you're struggling I'll take a look.
Andy.
