Hi al
how do i test front Spheres on a S2 Xantia? I have replaces rear, accumulator and anti-sink. the ride is a lot better but not the "magic carpet" i keep hearing about. actually it's good but, nut not as smooth as almost any other car i have owned.
Xantia Front Shperes
Sam KS
Citroën Xantia 75th Anniversary Limited Edition
Old-Guy
- x 33
Re: Xantia Front Shperes
Press down hard (or if you're fairly light, sit) on the top of each front wing in turn (as you would with a conventionally sprung car). Relatively, the springing should be rather soft and softly damped.
Citroenmad
- x 110
Yes, you can do the bounce test and see if you think it feels soft, however this is relative as what do you compare it to?
The best way is get the spheres to somewhere/someone who pressure test spheres
I took a wheel to be refurbished in my Xantia estate, the guy who came to get the wheel out pressed on the back of the car while getting the wheel out, it must have went down a good few inches. He turned and look surprised and said "did I just push that down?"
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Sam KS
ok, i have pushed down (I'm a big chap) on the front guards, with the motor off and it feels like a rock. like all the movement i am getting is from the tyre wall flex.
should it sink and come back up like the back end with the motor running?
Citroenmad
- x 110
That doesn't sound right. What model is your Xantia? Is it hydractive?
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Sam KS
I don't think so? it's got 6 spheres, 1 pump and hight controllers front and rear. dose that help narrow it down?
Citroenmad
- x 110
If its not VSX or Exclusive then its non-hydractive. In that case it should be soft to press on, you should certainly have more give than just the tyres. Sounds as though the front spheres need replacing.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Sam KS
Thanks, I'll get onto GSF and order some.
