Xantia - what size bolt?
citroenxm
Fallen Hero
x 70
Re: Xantia - what size bolt?
Unread post by citroenxm »
Do you mean where it goes into the Gearbox, or the ones that are bolted into the chassis rail....
Its a standard 13mm spanner head bolt... nothing special...on the gearbox..
I think thats called an M8 bolt..
The chassis ones are a bit smaller, i about to remove some this week from a car Im dismantleing, I think they are a 10mm Head bolt with flanged head (to mimmick a washer).. Not sure what the M size is..M6 if I have read Citroen Service correctly
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
Well mike if you can hang on a bit longer, I can remove and supply all the -ve bolts I need to remove from this M reg breaker. Ive not unbolted the earths yet from the gearbox or chassis rail just yet.. So could do that and pop everything I take off into a jiffy for you... Ive tons of the bloody things!!
Paul
A very sad...
1994 XM 2.1 d auto
