lexia
allanmc
lexia
Unread post by allanmc »
Hi been playing about with my new Lexia dont realy know what I am doing, anyway after I was finished the airbag warning lamp is flashing and also there are 2 permanent faults the injection system I know about but the other one says engine immobiliser faulty, its a true saying, a little knowledge is a dangerous thing, but as this is the second Lexia I have bought then I have to try it.
regards
Allan
Xantia 2.0i SX Auto, 1999
oneday
Re: lexia
Unread post by oneday »
did you get this from jim at easydiagnostics
306 1.4 LX MERIDIAN
allanmc
Re: lexia
Yes it it arrived on Wed.
allan
oneday
Re: lexia
if you get stuck get intouch with jim he is allways ready to help any of his clients he has helped me out a couple of times with mine im no expert either. if you can get on the net at the same time as you are hooked up to the car he will put it all right from his end
306 1.4 LX MERIDIAN
allanmc
Re: lexia
Dont know if I can do that but I will give him a call next week
allan
oneday
Re: lexia
someone on here may be able to help before then but at least you have got support now
306 1.4 LX MERIDIAN
DickieG
Monaco's youngest playboy
x 33
Re: lexia
Unread post by DickieG »
What car is this on Allan?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Mandrake
x 695
Re: lexia
Unread post by Mandrake »
Allan
Did you go into any configuration options or did you just stick to fault code reading, parameter measurement and actuator tests ? If the latter I can't see how you could have done anything harmful, however I believe there are configuration options for the air bags to enable/disable them in which case it might cause the flashing light.
What do you get if you try to read fault codes from the airbags ? With any warning lights always start by reading the fault codes of the applicable ECU.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
