Xantia Discs
froggy
- (Donor 2026)
- x 4
Xantia Discs
Hi, is there a min thickness for front or rear discs? How do I measure and with what? maybe a Vernier? many thanks in advance Terry . ( Xantia TD 1997)
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 8446
Re: Xantia Discs
Pass on the first bit Terry but a micrometer will be best so that the wear lip can be avoided which will be impossible with vernier calipers.
A basic far-eastern made micrometer can be picked up very cheaply these days. I think I paid a tenner for mine. Hardly a Moore and Wright but quite adequate for all normal workshop jobs.
froggy
- (Donor 2026)
- x 4
Re: Xantia Discs
CHEERS jIM
Terry
andmcit
- x 30
Re: Xantia Discs
The discs should be manufactured with a step in the outer circumference where
it will indicate the minimum thickness on e the disc is worn down to be flush with it.
Otherwise, doesn't the BoL Haynes have a max/min thickness?
Nothing moves you like a Citroën
Xantidote
- x 4
Re: Xantia Discs
The BoL which I have to hand covers Xantia up to N reg, and gives:
Front: New = 20.4mm, & 18.5mm minimum
Rear: New = 9.0mm, & 7.0 minimum
Martin
1995 Xantia TDLX (deceased
handyman
Re: Xantia Discs
The dimensions for the BOL applies to both Mk1 & Mk2, as this service part has not changed between the series. Do not forget to measure the discs on the outer and inner edges and at about three different places as they NEVER wear equally. As the discs get older, its also worth checking for radial cracks, especially on vented units.
H
H
