Suspension noises
87chopper10
Suspension noises
Hi all, my Xantia klunks and knocks on both sides over rough roads and potholes. Ive replaced the front and rear wishbone bushes on either side (passenger side totally worn), but its still knocking over bumps. How can i determine whether its a ball joint or drop link or anything else for that matter. I cant seem to recreate the noise while shes up on stands.
Citroenmad
- x 110
Re: Suspension noises
Tyr getting someone to rock the car from side to side while you have your hand on the drop link or ball joint. You should feel the knock.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
87chopper10
Thanks never thought of that. Now I've to beg someone to come out in the cold and and nag while i check it.
- x 94
if its almost continuous over bumpy roads then its 99% certainly drop links
Regards, malcolm.
87chopper10
Yeah it seems to knock continuously that's why i changed the bushes. I'll have a look in the morn see what the craic is.
87chopper10
Drop links fitted today. Handy job enough. Only found out about the Allen key hole in the bolt after nearly scorching one of my brake lines. Alls working fine now no noise whatsoever thanks for the replies.
- x 94
good to hear your sorted
Regards, malcolm.
Citroenmad
- x 110
Yes, good to hear you have solved the knocking
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
