xantia cambelt
froggy
- (Donor 2026)
- x 4
xantia cambelt
Hi , my Xantia 1.9 TD, Iam going to try and change the cambelt on my Xantia! ( never done one before!!) Would there be a" how to do " thread on the subject . Here"s PRAYING there is ! many thanks inadvance Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Xaccers
- x 185
Re: xantia cambelt
It actually is over all not that hard a job, although there are some moments which are complete PITA.
Be prepared beforehand for what you'll need.
Camblet kit of course, some people change tensioners every other belt change as they're pretty tough, but it is down to the individual, personally I'd change them.
Axle stands - put them under the front jacking points and set the car on low to give you enough room to safely work underneath without the engine being too high for a trolly jack under the sump which helps move the engine up and down to get at everything.
Water pump - you definitely want to change it, they don't like the belt being changed so better to be safe than have to do the job again. You want the type with the metal shield built in to the design, so if there's a metal plate sticking out of the pump by the pulley then you've got the right type (if you can see the pulley from all directions around it whilst holding it 12 inches or more away from you, you've got the wrong type).
Long flat screwdriver or pry bar or thin but strong bar - when you replace the tensioner the spring and plunger that keep it tense will drop out, so when you fit a new tensioner you'll need to push the plunger back inside its hole. Easier with a friend to fit the tensioner while you push the plunger back.
Lots of percy wotsit and maybe a few new swear words
Fresh coolant.
Have you considered replacing the aux belt auto tensioner while you're at it? Chances are if it's not been done recently the needle bearings have collapsed and the lower eye of the spring behind the hydraulic pump has fallen apart and is out of round.
Fresh coolant.
DIY sphere tool
DIY sphere tool
froggy
- (Donor 2026)
- x 4
Re: xantia cambelt
Cheers Xac
Terry
rory_perrett
Re: xantia cambelt
Crank pulley bolt can be a fight, better done with the engine up to temperature as that softens the thread loc. But as said, if you go steady the job is not that bad.
jgra1
- (Donor 2021)
- x 36
Re: xantia cambelt
rear upper cambelt cover bolt can be a pain.. mirror on a stick useful.. think it is normally a 5 or 6mm allen
Xaccers
- x 185
Re: xantia cambelt
11mm normal bolt if memory serves.jgra1 wrote:rear upper cambelt cover bolt can be a pain.. mirror on a stick useful.. think it is normally a 5 or 6mm allen
DIY sphere tool
DIY sphere tool
rory_perrett
Re: xantia cambelt
Or is it 10mm, I have it in the back of my mind that a flex head 10mm ratched spanner is useful for something in that vacinity.
Rory
Rory
lurchy666
Re: xantia cambelt
there is a how to on old-guys xantia page http://www.attfield.dircon.co.uk/xantia.html" onclick="window.open(this.href);return false; 3rd link down on the left if it is any use to you.
c5 2.2 auto hdi estate 52 reg
jgra1
- (Donor 2021)
- x 36
Re: xantia cambelt
sorry I meant the allen key size
5 or 6mm
at least, mine was an allen bolt.. later TD..
Xaccers
- x 185
Re: xantia cambelt
It's 11, the others are 10mm and that one is different to be extra awkward thenrory_perrett wrote:Or is it 10mm, I have it in the back of my mind that a flex head 10mm ratched spanner is useful for something in that vacinity.
Rory
John, sounds like a previous garage replaced yours, an Allen bolt back there must be a nightmare!
DIY sphere tool
DIY sphere tool
jgra1
- (Donor 2021)
- x 36
Re: xantia cambelt
ahh that could explain a few things
once i knew that a spanner wouldnt fit a round thing it was bearable
- x 94
Re: xantia cambelt
im with Xac on that bolt also the two on the lower cover are 11MM, sometimes the top front bolt is one of the allan variety ,
im in the proses of a cam belt on my daughters Synergie, that bak bolt is a stud with a 11mm hex a third of the way down the threaded section,
this screws into the back of the engine through the cover, then a bracket welded to a metal water pipe hooks over the stud with an 11mm nut to hold thet,
the water pipe runs up the back of the belt cover from the water branch, and it right in the way of getting much onto the nut/stud, so you have to fiddle to loosen the nut then remove the pipe to gain access to undo the stud
and its only the XUD lump
Regards, malcolm.
