206 2002 1.1 8 valve
joemadmec
Unread post by joemadmec »
hi got a 206 1.1 8v with an intermit fault where its only running on 3 cylinders put it on a launch x431 scanner and came up with these faults
injection supply signal 1 short circuit to positive (permanent)
air intake temp signal short circuit to positive (intermitt)
intake manifold signal short circuit to positive (intermitt)
injector supply signal 1 open circuit (permanent)
as anyone had this before thanks
Lighty
x 34
Re: 206 2002 1.1 8 valve
Unread post by Lighty »
Injectors very common on these, inspect the terminals with a mirror, very common for water to get in the electrical connectors, especially the end ones, ie 1 or 4
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
joemadmec
took wiring of to inspect today looks fine will get a new injector and try that thanks
