She liked the toys of my car but wanted a petrol manual. As the C5 II Exclusive petrols were all autos, she has settled for an 05 plated VTR estate in red. A dented bonnet lets it down but for £1,850, with 61k on the clock, it was very well priced and the body is fine otherwise, with the exception of a few light scratches.
It has led a pampered life, apart from the last owner, who has let it go a bit over the last two years. Still, I am going to bring it back to its former glory.
If anyone knows of a red C5 II bonnet near the Midlands / Mid-South Wales direction, let me know...
Anyway, I have had a Lexia session on it and a few faults keep returning, which I hope the experts on here can advise on:
1. Code F8EB - 'Absence of + perm on display' - I believe this relates to the multifunction display but that works fine, with no missing dots etc. Can anyone clarify?
2. Code 0702 - 'Passenger humidity sensor not defined' - I presume this means the air con humidity sensor is dead. I checked the reading and it thinks the interior humidity is 32768%. Does anybody know where it is located? I presume this is different to the temperature sensor, situated next to the glovebox behind the small fascia vents.
3. Code 0157 - External temperature info. This tipped up 312 times, according to the log. It looks as though the passenger side mirror has had a clout, as a replacement glass is glued over the original. Yet, the external temp is displayed OK on the multifunction screen. Does the climate control take a reading from this sensor?
4. Oh and the passenger side mirror does not heat but I presume that is down to the damaged glass. Is the heater element within the glass or is it separate?
Any help is appreciated.
Rob
