Tyre Wear
froggy
- (Donor 2026)
- x 4
Tyre Wear
Hi, The front nearside tyre on my Xantia is wearing on the inside edge. I had them tracked and balanced about three months ago. My question is; should I be looking to check any bushes or suspension parts? or even getting them re tracked ? many thanks Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
DickieG
- Monaco's youngest playboy
- x 33
Re: Tyre Wear
Before spending money on tracking take a look at the condition of rear bush on the lower suspension arms, any signs of cracking or splitting and they're knackered, if you get the tracking adjusted before checking/fitting new bushes the alignment will be set incorrectly and you'll have to get it done twice.froggy wrote:My question is; should I be looking to check any bushes or suspension parts? or even getting them re tracked ? many thanks Terry .
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
froggy
- (Donor 2026)
- x 4
Re: Tyre Wear
Cheers
Terry
- x 1240
Re: Tyre Wear
If the tracking was at fault both tyres would be wearing, I have known this be caused by the tyre itself being defective but check the bushes as Dickie says.
froggy
- (Donor 2026)
- x 4
Re: Tyre Wear
Anybody got a picture of the bushes or diagram in relation to whereabouts I need to look. sorry for the question but Iam abit green! Haynes manual NO help.
Terry
- x 94
Re: Tyre Wear
look at the front suspension arm below the hub, folow it to were it is bolted onto the sub frame there you will see a bush at both mounting points,
a bush at the front end and a ( P bush ) at the rear end,
DickieG is referring to the rear ( P bush ),
although play in either of the arm bush's or the lower swivel joint can/will cause tyre wear
Regards, malcolm.
froggy
- (Donor 2026)
- x 4
Re: Tyre Wear
many thanks
Terry
froggy
- (Donor 2026)
- x 4
Re: Tyre Wear
Iam just hoping! I have found some P bushes that I had bought for the wifes peugeot 306(2000) could I use those for my series 1 Xantia?
Terry
