Xantia HDi front headlights
Taffyrhys
Unread post by Taffyrhys »
Hi all
As you are all aware the front head lights aren't that great and i was wondering if I uprated the headlight bulbs to 100w instead of the 55w standard bulbs, will it burn out the wiring or blow a fuse? Do they also make a differnce? 8-) 8-)
Cheers
Taff
Xaccers
x 188
Re: Xantia HDi front headlights
Unread post by Xaccers »
Check what voltage you're getting at the bulbs, could be you need to do the relay mod.
DIY sphere tool
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Re Xac's advice here's an excellent link giving you all the information to judge whether you need brighter bulbs or (more likely) to fit relays.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
neil123
Unread post by neil123 »
Mine have always been excellent, except when I replaced the dipped beam bulbs with a particularly crap brand, (which sounds like a telephone does when it is trying to attract your attention!) as it was all a garage sold. Replaced them with a pair of decent quality bulbs, Philips or something similar, and they were fine again - apparently the accuracy of forming and placing the filament in the bulb makes a huge difference to beam pattern and efficiency, and the 'generic' crap bulbs are nowhere near as good as they should be. Top tip - an 'E' approval number in the range 1- 4 is very desirable - other countries tend to be 'slightly' less stringent in their approval tests - ie one lamp tested for approval, rather than one from each batch produced.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
I did the relay mod, and upgraded to (cheap) 100's.. both helped.. :)
DickieG
x 33
Rather than overload the wiring with 100w bulbs fit relays and maybe some Philips Brilliance bulbs and you'll have all the light you need.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
lurchy666
Unread post by lurchy666 »
my hdi has the relay mod for low and high and i stuck 100 watts in all the lights including foggys, really makes a diffrence,
c5 2.2 auto hdi estate 52 reg
