How do you replace the radio/clock light
stu9
- x 8
On the 03 C5.....the one at the top of the dash, how does it come out
citroenxm
- Fallen Hero
- x 70
Re: How do you replace the radio/clock light
Get the flat blade screw driver... and lever it out...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
stu9
- x 8
Thanks....I was do that earlier but thought there must screws somewhere but didnt see any, that's why
citroenxm
- Fallen Hero
- x 70
IF theres a surround trim, that may lever out first.... then possibly screws for the display..
Im getting a bit fuzzy nw with the picasso central display, they lever out..
There will be another C5 owner along soon no doubt to confirm or tell us we are wrong...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
SaabC5
There are four securing tabs, two top two bottom. If you gently prise up the bottom two you can then pull away the whole surround. The display is held in by two torx screws, undo them and you can then access the twist fit bulbs (3) to change them. Refit is the opposite of removal but be careful of the TrafficMaster led bulb which has a ridiculously short wire
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
