Where do I buy?
Where do I buy?
A waxstat for a 1994 (L) Citroen Xantia 1.9d?
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
Re: Where do I buy?
here is price and part No. from citroen
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000164762 IDLE CONTROL 24.61 GBP 29.53 GBP 29.53 GBP
this is the one listed for an N/A MK1 diesel XANT, but if you send me the last 8 digits of your chassis/VIN No. i will check just to make 100% sure its the correct one for your car
here is a list of citroen models this one fits
Number of documents found by vehicle family:
1 document(s) found for SYNERGIE
1 document(s) found for XANTIA II
1 document(s) found for BERLINGO (M59)
1 document(s) found for BX
2 document(s) found for RELAY
3 document(s) found for C15
5 document(s) found for XSARA
4 document(s) found for BERLINGO
6 document(s) found for ZX
4 document(s) found for DISPATCH I & II
4 document(s) found for XANTIA
1 document(s) found for XSARA II
Regards, malcolm.
Re: Where do I buy?
Thanks Looks like it's common to quite a few cars then.
I'll PM you my chassis number
Re: Where do I buy?
yep thats the correct one for your chassis No.
Regards, malcolm.
Re: Where do I buy?
Thanks off to see if they have one.
Re: Where do I buy?
They didn't have one
I'm going to readjust and check mine properly over the weekend and if it is definitely faulty (I'm pretty sure it is) order one on Monday
Re: Where do I buy?
Well,
Set the idle correctly when the engine was fully warm (it was previously too high) and then when the engine was cold adjusted the waxstat cable so that the lever was pulled fully into the advance/high idle position.
The engine wasn't quite fully warm on the way home but the waxstat cable was still tight at this point, so it's looking like it is indeed faulty and I'll need to order one on Monday.
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
Re: Where do I buy?
There is not a great deal in them difference wise. I actually used a Renault unit on my 205, the cable was far too short but once I'd sorted that out it was actually better than the PSA one as it would rapidly open compared to a new standard one.
As they age they move less that's all up until they do not move at all or hardly. The easy setting method I find is to just do it with a warm engine, ensure when hot there is a bit of freeplay in the end fitting, the amount of freeplay you may adjust later if needed. Basically when its cold the next day just look to see how much its pulling the fast idle arm. I tended to have mine not quite fully pulled tight as it took too long to come off that way but each to their own.
Andy.
Re: Where do I buy?
Well as I thought it's not working.
Ordered one today it should be here on Wednesday
Re: Where do I buy?
Finally got this fitted today
The old one was date stamped 10/93 so I'm guessing it was probably the original. It had been out before however as it had had sealant applied to it as well as the seal.
I fitted the new one with a new O ring seal from my selection box again
It's all working lovely now, I didn't check the new one but the old one was marked 40 degrees on the internal part. Sure enough it came off just before reaching the 60 degree mark on the temperature gauge.
That should help the cold starting/running and the fuel economy It's nice to have a proper idle speed when warm too. The engine sounds much quieter at tickover now
