Muggle wrote:Citroenmad wrote:Re sidelights on the 56plate C5. They are in the top of the headlight, there is a small rubber cover which you will see with at top. Remove that and deep inside there is the sidelight bulbs. It is a fiddle, there is very limited room and it requires the batter to be removed if on the NS. They go quite frequently on the facelift C5s, I have replaced mine with LED bulbs as they last much longer.
Hi and thanks for your reply. Can you tell me what led bulbs you got and where from? Since posting, one of my friends told me that he was told the bumper had to be removed in order to change the sidelight bulb - did you need to do that or is it possible without? I will take the panels off and have a look once I have time and am not working. Thanks in advance for any help you can give me
No, you don't need to remove the front bumper. You also don;t need to remove the front bumper to replace the headlight bulbs, though I have seen people do it. I've replaced them fine without. The C5I and C5II (facelift) are different for access and sidelight bulb requirements, this is the C5II im describing.
You will need to remove the battery to gain access, but otherwise just the top plastic under bonnet covers will need removing. Towards the top inner area of the headlight you will find a rubber plug, pull this off and the sidelight is deep in there. They dont push in and turn, they simply are pushed in. Pulling them straight out will release them. Some of the ones I have done have tighter clips on the bulb holder than others, you you might need to press in the 'tabs' on the bulb holder to release it from the headlight. It takes me about 5-10 minutes but I've done it a good few times now.
These are the ones I got:
http://www.amazon.co.uk/gp/product/B004 ... 00TA4923YW" onclick="window.open(this.href);return false;
Since replacing mine with these they have not needed replacing. Our C5II estate is still on standard type bulbs and has eaten through a pair in the time I've had these. There is one out on that car now, so I'll no doubt order some more LED bulbs. They are a little blue, but not too bad and if they last longer, thats all I'm bothered about.
