Is there any pictorials on how to remove
stu9
- x 8
A 2ltr hdi C5 diesel injector....I cant find anything either here or just on Google in general
stu9
- x 8
Re: Is there any pictorials on how to remove
I found this....this is quite a high tech kit, a basic kit the same idea is about £120ish.....but all that to get them out when siezed
and number 4 on mine is
Stiill....cheaper than a head/engine....well maybe....by the time you buy a new injector and that tool....
" onclick="window.open(this.href);return false;
stu9
- x 8
Im shocked that after 30 views, no one knows anything.....i know i found the vid but surely someone's did this and knows how hard/easy it is
oneday
hi 30 views is not a lot you just have to wait for the correct people to view your question
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- x 2941
Removing the injectors on the 2.0L HDI is pretty straightforward, the only extra advice is that should the injector be seized is to remove the stud that the forked clamp is held by and use a spanner on the injector in the slot that the fork fits into to twist it loose.
oneday
there you go easy when you know how and a lot cheaper
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
