Laguna Rear Screen Problem
HarrysMate
The rear screen heater on my Laguna (1995 RT) is not working. No voltage at connections. Have tried swapping relay - no joy. Power must be available at the relay as the wing mirrors are demisting OK and according to the Haynes manual are fed from the same relay contacts. I would like to check out the wiring but don't know its path through the bodywork. Any help appreciated. Thanks.
Dave Burns
- x 3
Iain Park
When I bought my laguna, also an RT of 1996 (2.2d) I had exactly the same problem. I returned the car to the garage and they set about TRYing to fix the problem, well they did albeit at the exspense of my heated door mirrors. So now I have a working Rear screan but no heated door mirrors. Would appreciate help on how to remidy this if you succeed with your problem.
All the best.
All the best.
