405 sun roof drain tubes
x 94
Unread post by citronut »
does anyone know were the bottom ends of the drain tubes terminate and how to get at them, this is an estate
i have not looked at the car yet
Regards, malcolm.
spider
x 77
Re: 405 sun roof drain tubes
Unread post by spider »
Off hand no, although I may have an ancient BOL on a 405 somewhere, not sure if it will provide any clues.
I'll look at the proper PSA parts diagrams later although I guess you have access to these anyway. I would suspect the usual ie the far ends of the sill or possibly the wheelarch area.
Andy.
x 94
ok thanks Andy
yes i do have access to pug service box,
they dont seem to terminate were BX tubes do, rears behind the rear lamps and fronts inside to bottom of the A post's
Regards, malcolm.
spider
x 77
As expected there's nothing but the exploded diagrams, nothing to indicate the drain pipe path. Well not that I could see.
Not a lot in the BOL either, there are a few hand drawn pictures but they do not really show the tubes, only that they appear to go straight into the pillars, nothing more (but that's obvious they'd go there)
What's the problem with it ? , can you not pour a tiny amount of water into each 'corner' of it to see where it appears initially ?
Andy.
Oldpug
x 94
Unread post by Oldpug »
All I know is they run down inside the screen pillars and if you pour water down from the top it runs out by the front of the sill from inside the wing.So to get at it you must have to remove the wing and inner wing??
