HDi Xantia NOT on death row.. shes fixed.....
citroenxm
- Fallen Hero
- x 70
Hi all...
Despite me being a BIG fan of the HDi 8v engine, and still rate it the BEST I do have a small issue with my Exclusive, and its a very Dangerous issue too! Im just gonna run it by you others and see if you have any other ideas...
Firstly, what started happening was under heavy accelleration, the engine would suddenly cut out DEAD.... and wont restart again untill the key has been turned off for at least 5 seconds or more... only then she will start and then power returns slowly!
First sugestions were about a yellow plug that sits under the top hose, and to clean it up. I did.. but also I had switched to gentle accelleration... so the cutting out wouldn't happen...
Next now, the car started running on after the key was swtiched off for a good 5 seconds, this also put the management light on, and limit my to 2400 rpm... I knew what this was - the pressure regulator in the end of the engine fuel pump. After a swap of this normal service was resumed. I however, also, while swapping the fuel regulator in the pump I also decided to swap the Throttle Sensor under the LHM tank, the fuel rail pressure sensor in a hope to solve my problem.
So I got braver with the accelleration and hey presto, the cutting out issue is still here! What I have also done as a process of ellimination, I have removed the yellow extension harness, as it only extends the harness to the pressure sensor. However, by cutting a ridge off the Red Plug it can be plugged into the sensor DIRECTLY!
With all this in mind, tonight was a real dangerous one, as I pulled off a round a bout with traffic on my left, foot down - BANG stop! in the outside lane!! ?? So, all I could do was coast into the left lane right in front of the car behind, then while slowly reducing speed, trying to get the thing going again I finally got her going, and managed to get going... after that, she went brilliantly, as always ... Its just the initiale foot down!
So, where do I look now?? The parts Ive changed have all come off a PERFECT engine that didnt cut out...
So what do we think, the cars main loom??? Something else?? Time to retire??? (The car that is)...
Shes only got 225k on her... I have got replacment harness I can fit...... if she needs..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DickieG
- Monaco's youngest playboy
- x 38
Re: HDi Xantia on death row UNLESS shes fixed.....
Have you tried unplugging the tuning box you have on it Paul? I recall reading somewhere about someone with a C5 having similar issues due to a duff tuning box.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
citroenxm
- Fallen Hero
- x 70
Oooo forgot to say.... Tuning box IS NOT FITTED.....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1457
Got to get it on the Lexia and see what the live data is doing....
Rail under / over pressure, earth fault, could be anything really unfortunately!
citroenxm
- Fallen Hero
- x 70
Been there done that.. nothing obvious shows up to me... figures all look fine, all that happens when i put my foot down the pressure ref goes up and while the actual fuel pressure rises pop stop ... the fault recorded is " fuel pressure reference LOST " so the Ecu is loseing where the throttle is.. the throttle on it now is off a faultless engine...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Citroenmad
- x 110
It does sound like a fuel problem, pressure sensor?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Northern_Mike
If this were a petrol, I'd suspect the throttle position sensor. As I have no real clue about these HDI motors, I can't help, but it sounds like something electrical to me.citroenxm wrote:Been there done that.. nothing obvious shows up to me... figures all look fine, all that happens when i put my foot down the pressure ref goes up and while the actual fuel pressure rises pop stop ... the fault recorded is " fuel pressure reference LOST " so the Ecu is loseing where the throttle is.. the throttle on it now is off a faultless engine...
citroenxm
- Fallen Hero
- x 70
Citroenmad wrote:It does sound like a fuel problem, pressure sensor?
been there Chris.. this is what's stumping me now.. all the fuel stuff is off a car with no issues... hence me now thinking the engine harness...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Citroenmad
- x 110
Can't be an ECU problem can it?
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
DickieG
- x 38
Paul have you looked in the HDi diagnosis manual to work through the flow chat according to whatever fault/s are recorded? If not this could take a fair bit of tracking down. What particular fault/s including codes are listed?
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
citroenxm
- Fallen Hero
- x 70
Open to ideas.. ive got a matching Ecu and Texton box.. could try them i guess...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
DickieG wrote:Paul have you looked in the HDi diagnosis manual to work through the flow chat according to whatever fault/s are recorded? If not this could take a fair bit of tracking down. What particular fault/s including codes are listed?
just the one mentioned i think above .. loss of fuel pressure reference.. Im currently lexia less as i broke the screen but awaiting a new screen to arrive.. is the flow charts in lexia or a handbook??
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DickieG
- x 38
You'll also need a matcching key.citroenxm wrote:Open to ideas.. ive got a matching Ecu and Texting box.. could try them i guess...
The diagnosis manual is a separate book, I'll dig one out tomorrow and see what I can find, if you could identify the exact code that will help a fair bit as I fear they may be several fuel pressure flow charts according to the exact code recorded.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
citroenxm
- Fallen Hero
- x 70
Yes i have the key too... from the last Hdi i just got rid of...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
DickieG wrote:You'll also need a matcching key.citroenxm wrote:Open to ideas.. ive got a matching Ecu and Texting box.. could try them i guess...
Thanks Richard.. much appreciated.. When my screen arrives i can do something.. be next week now..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
