Thanks in advance
Xantia track rod end thread diameter
XantiaDaveEire
- x 4
There's 2 different size track rod ends coming up on A.E.P direct for my car (1998 1.9 TD) so which is the correct size diameter 18mm or 22mm?
Thanks in advance
Thanks in advance
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k
- x 1480
Re: Xantia track rod end thread diameter
The larger one is only fitted to the bigger engined variants with the ML gearbox (or the auto fitted to the V6), eg 2.1TD, HDi 110, V6 and 2.0T. Yours will be the smaller one.
XantiaDaveEire
- x 4
Thanks Richard
