XUD noise, injector leak?
caspar
Unread post by caspar »
My ZX1.9D has recently been making a sort of chuffing noise, especially when starting from cold. Seems to fade away when warmed up.
At first I thiught it was an exhaust leak but had a look round and found nothing.
Starting to think it could be an injector leaking.
What's the best way to confirm this?
Listen with a screwdriver on each injector in turn or maybe some soapy water around the injector and look for bubbles?
Thanks.
x 1240
Re: XUD noise, injector leak?
Unread post by Peter.N. »
Yes that would do it but if its leaking enough to hear you should be able to find it, if it is leaking it may have an accumulation of a tar looking substance round the joint.
