Citroen C5 1.6 HDI engine starts and cuts out in 3 seconds
jeyjey1982
hey guys, I have replaced engine on my Citroen, and for some reason car starts for few second and cuts out, everything is connected, and original injectors in place, anyone had something similar? Help
- x 94
Re: Citroen C5 1.6 HDI engine starts and cuts out in 3 secon
i dont know much about the electronics involved here but it sounds like an immobilisers fault,
maybe something still on the replacement engine you need to swap over from old engine ( fuel pump ?????? )
Regards, malcolm.
SaabC5
Don't think it would run at all if immobilised. Have you had work done on the engine thats started this problem?
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 1240
Could be air ingress to the fuel system.
- x 94
i have seen a V*A*U*X*H*A*L*L start and cut straight out before with an immobilisers faultSaabC5 wrote:Don't think it would run at all if immobilised. Have you had work done on the engine thats started this problem?
Regards, malcolm.
MichaelH
If it starts then stops this is more like fuel. Check your high pressure manifold sensor. Low pressure pump will energise, engine cranks and high pressure pump delivers (at something over 150psi). If pressure drops off the ecu will shut down injectors. (You may be able to con it by shorting out). Check fuel filter as sometimes a blockage will provide enough fuel to crank to 150psi but once the first injector opens it drops and ECU shuts down again.
I presume you have checked fault codes, watched lights etc. to see if management light comes on?
You might try a dynamic monitor. (I don't have Lexia but Autel etc. can dynamically moitor and you can see sensors drop off)
Mike
Mike
UK Midlands currently with C5 (X7) Exclusive 2.0 HDI + 2 Pug 306s (Meridian and L) and a Pug 206L a/c
Previous C5 1 Exclusive 2.0 HDI, Pug 407LX HDI, 2No. Pug 406s LX HDI, Pug 309GLD, Pug 205GL, Pug 505GL, Pug 604SE, Pug 504ti
jeyjey1982
Hey guys, I was reading somewhere, that I can reset immobilizer some how, and where is no codes or management light
- x 1056
Some maufacturers imobiliser systems do start & run for a second or two when the imobiliser system is active, the ones i can think of off hand that do this are Vauxhall & VAG cars. I cant say im aware of any PSA cars that do this though.citronut wrote:i have seen a V*A*U*X*H*A*L*L start and cut straight out before with an immobilisers faultSaabC5 wrote:Don't think it would run at all if immobilised. Have you had work done on the engine thats started this problem?
Why was this engine changed in the first place ??
jeyjey1982
Fuel pump is on from Focus, probably that is the cause, ill try to swam them next week and will see
- x 94
so has this fault has only shown itself since the engine change, and has the engine run as it should at all since the engine change,
if not o would think it must be something on the replacement lump that needs swapping over from the old one,
Regards, malcolm.
jeyjey1982
car is finally on the road, I changed fuel pump and rail pressure switch from old engine, started from one key turn, happy days now
- x 94
wonderful it had to be something like that
Regards, malcolm.
jeyjey1982
Thank you for all helpcitronut wrote:wonderful it had to be something like that
