I am still in the very early stages of Xantia ownership and already getting used to fixing little things here and there.
I was speaking to a friend about checking for a blown fuse(regarding stereo not working), I went inside to make a coffee and come back to him just removing random fuses.
Upon him leaving, the coded ignition is not showing any coloured lights and the engine will just start. How ever the alarm keeps going off when I get inside the car.
I have a blipper key but that no longer works so I have been using the key in the lock to activate the central locking!
It is driving me mad. Has anyone had a similar problem or can suggest what to do to stop this.
thanks
Xantia Temptation R Reg Alarm and Coded Ignition Help
lloydspencer
- x 1060
Re: Xantia Temptation R Reg Alarm and Coded Ignition Help
If all the other stuff was working ok before your mate started messing about with fuses then work backwards from there, I'd put money on he has removed a vital fuse & put it back in the wrong place. Get the fues diagram from the handbook & check all the fuse positions match up with the equipment fitted to your car, there will be blank spaces in the fusebox for higher spec models, the chances are he has fitted the vital fuse(s) into one of them.
citroenxm
- Fallen Hero
- x 70
He has disabled the Keypad, which I beleve after unlocking the ECU with the correct code, if then remove the power to it or the plug you then DO NOT need to enter a code again, untill power is resotred to the keypad.. NEVER forget your code though.lloydspencer wrote:I am still in the very early stages of Xantia ownership and already getting used to fixing little things here and there.
thanks
To reset your alarm, theres a button on the dash with a Speaker shape with a cross on it.. I beleve Temptations have no rear elec windows so it should be the ONLY one on the right..
If you disconnect your battery again in the engine bay, then reconnect, switch on the ignition to second position while HOLDING the dash button on the right the indicators should flash rapidly to indicate alarm reset...
As for your plipper, we can fix those, if you want to send your inners to me, I can sort it out and send it back for you working!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
lloydspencer
Thank you very much for your replies.
I doubled checked all the fuses to make sure they were all in the correct places.
I found a few that were the wrong rating. Whether they were all him or some.
Will be getting a couple of new ones next time I am out and about.
Thanks citroenXM I have reset the alarm! All good now. And I have pm'd you about the key
