C5 diesel sucking in air
marco f1
Unread post by marco f1 »
hi all a think my c5 is sucking in air when i rev it up there is a sound like its sucking in air i know the sound of the turbo but this seems a lot louder than normal.. and when i look under the bonnet there is a large pipe with 2 or more small pipes going into it witch have a valves on them and thay seem to be leeking oil these are at the front of the engine inthe middle.. i dont know what thay call it but one of the big pipes is a air pipe and i think it goes to the turbo
any help
marco
citroen C5 vtr 2.0 hdi 138 bhp 54 reg mk
live life a quater mile at a time
x 5657
Re: C5 diesel sucking in air
Sounds like the turbo pipe Marco, runs from the intercooler over the engine.
Have you noticed a fall-off in performance?
Worth removing that pipe and giving it a thorough inspection but you may be able to locate the leak by spraying the pipe with WD40 or similar with the engine running, the sound will change when the spray falls on the leaking bit.
It may be just the hose clips are loose too.
x 1438
Unread post by xantia_v6 »
Don't the intercooler pipes run at positive pressure?
x 5657
xantia_v6 wrote:Don't the intercooler pipes run at positive pressure?
That's a thought :oops:
Possibly the pipe beside it that runs from the airbox to the turbo.
marco f1
thanks guys for your info.... but i am going away to work tomorow so i have give the car to the garage who fitted my clutch just to see if thay can sort it out, maybe thay havent put a pipe on properly or knocked something when thay fitted the clutch.. who knows but i will proberly get charged if its there fault or not... i will keep you all posted
many thanks
marco f1
