Xantia Wiper Blades
Malcolm
Xantia Wiper Blades
Unread post by Malcolm »
Is there a supplier for wiper arm spray bars for the Xantia, to replace the jets. I have these on the Pug and want them on the Xantia
andycarter
Unread post by andycarter »
Thats odd, I'm sure I saw something here last week about a pug owner who wanted the spray jets from a Xantia ...
You guys must swap cars [:p]
AndersDK
Unread post by AndersDK »
Malcolm -
I'm sure Andy is referring to this thread :
http://www.andyspares.com/discussionfor ... IC_ID=4073
This spraybar fits both BX'es & CX'es - would be surprised if it does NOT fit a Xantia - or could not easily be modified.
One snag however :
The use of the spraybar requires a thru hole for the washer feed in the wiper arm axle - if this is not found on your Xantia - then it MAY be a bit complicated/clumpsy modification - depending on existing holes from spray jets.
blueboy2001
Unread post by blueboy2001 »
A mod I've been considering for a while is trying to fit Xsara/C5 jets to the Xantia. For anyone who hasn't had the pleasure, they are like a small pressure washer nozzle, require no adjustment a cover about 80% of the screen. I find you end up using a lot less water and still get a cleaner screen than normal jets.
