Hi newbie here,
i have an odd problem with the 306 i have just bought as a workhorse, the central locking wont work properly off the fob
the symptoms are
locking
it will lock fine from both the drivers and passengers door with the key
when using the fob i the doors will lock then bounce open again , the drivers door pin doesnt move at this point which i think is causing the problem
i have to then lock the doors manually with the key then i can use the fob to deadlock all the doors and indicators will flash correctly
unlocking
when i use the fob to unlock the car all doors with the exception of the drivers door will unlock , the indicators will flash , i then have to unlock the drivers door with the key
i hope i have gave enough information on the problem
thanks
Paul
central locking problems
Gingerposer
- x 6
Re: central locking problems
Paul, I had the exact same symptoms as discussed in this thread
http://www.frenchcarforum.co.uk/forum/v ... =3&t=35879" onclick="window.open(this.href);return false;
turned out it was the lock unit in the drivers door which was at fault. There are quite a few other threads on similar topics but this should be a fair place to start.
It wasn't that daunting a job to undertake (or expensive) and I am now very proficient at removing a S2 Xantia drivers side front door card!
Ainslie
Ainslie
- x 94
a lot of the time on the 306 it is down to one or more wires broken in the door shut
Regards, malcolm.
paul-zx6r
thanks lads, i have checked the wires in the door loom and all are fine, gingerposer, when you say the door lock is it the barrel???? or the latch part with the solenoid/actuator in
thanks
thanks
Gingerposer
- x 6
It was the central locking unit with the actuator in it.
paul-zx6r
thats great thanks for the help ill get one from the scrap yard today hopefully will cure my problem
anmosawi
hi,
i had just the same problem with this popup central locking system.
have just taken out the big (all in one) plug, which goes from the body to the door, clean it and spray it with WD-40 and put it back again. every thing works now as a clock.
