C2 Esp/asr fault, help!
stevo8375
Unread post by stevo8375 »
Ive got a C2 by Loeb (Vts) 2007 1.6 16v and i have a fault with my Esp/asr. I have had the car code read by a garage who it was the brake pressure sensor. But ive also heard of brake light switch failure causing issues aswell. I bought a switch and tried it on but still have the fault there...if i reset the bsi after fitting the new switch would this help? any advice very much appreciated im at my wits end!
2007 C2 By Loeb no.0157
Lighty
x 34
Re: C2 Esp/asr fault, help!
Unread post by Lighty »
Usually this fault is within the ABS Ecu, it is under the n/s front wheel arch liner, behind the front bumper.
A local company to me has repaired at least two for me, but lately everyone I have sent them is apparently scrap.
They cost between 4&5 hundred quid new, and need to be configured with Lexia I am afraid
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
stevo8375
Not what i wanted to hear.....but thanks all the same! My Abs functions as normal though which is strange, wonder if the esp can be deactivated permanently (as im not fussed about it anyway).
stevo8375
would Lexia be able to disable esp premanemtly?
Lighty
x 34
Don't think so
Citroen C15
Citroen Ami
