Recently purchased 2.0 Estate 1994 , genuine 58000 miler . The orga shows that the car has hydractive 11 suspension .
The suspension to the front of the car is on the bump stops unless the lever is in the high position (when of course the suspension is hard both front & rear ! ) . As soon as the height lever is moved to the "normal" position , the front immediately collapses down onto the stops - the rear comes down to normal positoning and is soft/operating correctly .
The car has almost brand new spheres to the front - the front height corrector (which was dignosed by Citroen agent as being the component in trouble) was replaced last weekend , but to no avail.
The car suspension "hops" at the back about 2 inches when the car is first started - but doesnt appear to affect the working of the suspension afterwards.
There is a sphere under the passenger seat , which "buzzes" for 3 minutes or so when the car front doors or tailgate are opened when the ignition is switched off .
Have a feeling the problem is computer , rather than hydraulic based , but any thoughts/ideas would be very welcome before I go any further ! Read somewhere that suspension fall-back mode is to hard setting .... can the computer be reset without the intervention of a Citroen agents equipment ?
Many thanks in advance !
XM - hard suspension
allmond
My Xantia buzzes like that - always assumed it was the relays on the valves which switch from hard to soft. If I stop my car and press the rear it goes up and down nice and soft. After about 30 seconds the buzzing stops and the car switches to hard mode - the default when ignition off etc. Is it a fault? I'm not sure, however, I occasionally get a hop like you describe. I thought it was a flat hydractive sphere so changed them and all was well for a few months, but now the hop has come back sometimes - not every day. Has my new sphere failed on me?
Jon - what's the warranty situation on the spheres?
Jamie
Jamie
Kered
I have VSX Xantia and have been mystified for some time by the very faint buzz. Due to a recent hydraulic pump problem I spent a lot of time under the engine and can confirm that the buzz is set off by just opening a door or the tailgate. Around 30 secs later there is a "clonk" and the buzz stops. I'm sure that it comes from the front Hydractive unit. I guess that it's not a fault but it sure is odd. I get the "hop" as described above but put it down to worn struts - having done 110,000.
Derek
Derek
blueboy2001
Tepi
My VSX with Hydractive II suspension makes that buzzing sound when (even engine off) you open the door and have the engine bay open (to hear it of course). I think the sound comes from the alternator and that is becouse the suspension has become active and change the hydraulic valve settings.
It is a feature, not a problem as far I know. I had a PDF document about HydractiveII which was very informative and interesting.
One thing is funny: set your radio to AM ~150-160KHz (hope your antenna is plugged in) and the buzzing sound tells you when the suspension is in the soft or hard mode. Click the Sport-button to increase the sensitivity of hard mode, and then make evasive movements -> whirling sound from the radio. Very cool... [8D]
The C5 has electrical hydraulic pump so that could be making that sound.
NiSk
Read from the following link and see if you understand it a bit better:
http://www.tramontana.co.hu/citroen/sus ... suspn.html
//NiSk
//NiSk
