C5 2.0 16V HDI 138 thinks its a DW8
x 94
Unread post by citronut »
i fitted a new cam belt kit and water pump to JohnD's C5 2.0 16V HDI 138 on thursday, i had to almost shoe horn the belt onto the sprocket and tensioners :shock: :twisted: :roll: ,
just like the DW8 belt i really thought it was not going to give just that tiny bit more ](*,) :-** :spineyes:
nice to meet you John
Regards, malcolm.
JohnD
(Donor 2022)
x 72
Re: C5 2.0 16V HDI 138 thinks its a DW8
Unread post by JohnD »
Yes Malc - nice to meet you too. Throughly enjoyed the day. Can't get over how easily that crank bolt came out :P
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
spider
x 77
Unread post by spider »
I had this problem once with an XU10 unit (if I remember it was a 306 GTi) , they changed the belt / tensioner arrangement so the replacment tensioner needed the 'newer' belt (it was new!) , I forget the specifics but it was something like 139 vs 138 teeth on the belts :( :D :)
Would of been nice if I'd of been informed in advance. :)
Andy.
x 94
spider wrote:I had this problem once with an XU10 unit (if I remember it was a 306 GTi) , they changed the belt / tensioner arrangement so the replacment tensioner needed the 'newer' belt (it was new!) , I forget the specifics but it was something like 139 vs 138 teeth on the belts :( :D :)
aaaah that would explain it, although both belts had 117 teeth i think it was, and i think i did hold the new and old tentioner against each other, i dont remember doing the same with the new idler though,
the other think i found is my flywheel locking tool ( long length of 3/16th copper brake pipe ) would not enter the flywheel locking piont/hole hardly at all, just look at it and it would drop out,
Regards, malcolm.
JohnD
(Donor 2022)
x 72
It seems the flywheel hole is 8mm and maybe not very deep so 3/16 rod would be very loose.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 8423
This is a big problem when doing a cambelt on a V6. It seems to be one tooth too short however you try. Fun :twisted:
x 94
JohnD wrote:It seems the flywheel hole is 8mm and maybe not very deep so 3/16 rod would be very loose.
i didnt find 3/16th to small/loose i just felt it wouldn't go in/locate by very much at all, as though it was just the tip entering a small dent rather than a peg hole in the flywheel
Regards, malcolm.
