Xantia V6 3.0 2000 antifreeze/coolant
evlo
Unread post by evlo »
Hello,
i can't seam to find the correct antifreeze (coolant) liquid for my car. And also cooling system capacity.
I have Xantia V6 3.0 2000 - engine is ESJ9 i think.
Can you please help me? As temperatures are attacking 0 celsius here. An i have only destiled watter in the system.
Sam KS
Re: Xantia V6 3.0 2000 antifreeze/coolant
Unread post by Sam KS »
http://www.olyslager-lubricants.nl/eni_ ... f29fc2188d" onclick="window.open(this.href);return false;
it looks like the capacity is about 10lt (there things are never exact on qty's) and will take either
http://travel.eni.com/catalog/products/ ... _2_201.pdf" onclick="window.open(this.href);return false;
i assume you are in pomgolia so available from http://www.motoworlduk.co.uk" onclick="window.open(this.href);return false;
Citroën Xantia 75th Anniversary Limited Edition
evlo
I'm in Czech republic. Thanks you for the link. It would be best for me if somebody can post the excact spec. requirement as i don't have owners manual at hand right now and can't get my hands on it :(.
It would seem from the agip site that the G11 compatible coolant would be ok and these are most common in here. Also i guess that the not correct one is better then only distilled water when temperatures are bellow zero :)
Sam KS
all the major lubricant suppliers will have a listing, at least the good ones will. just do some googling on the brand you have access to.
