Temp. reading
xenton
Temp. reading
Been meaning to ask you knowledgeable lot this for a while now. The temp on my display always shows 61 degress C, always, never changes. Is this a sensor gone somewhere and is it an easy fix?
Mark D.
2001 C5 2.0 HPi exec.
spider
- x 77
Re: Temp. reading
I think (until you get a correct answer) the sensor lives in the left hand mirror, regardless of LHD / RHD. It should be easy to replace once you remove the mirror glass (without breaking it!) in most cases.
Note I'm basing this info on 406's / 306's though...
I would expect it to display -- if the sensor had died completely though. Not sure if a Lexia will assist with this or not actually. I would guess it would at least allow you to read the outside temp sensor and then you could compare it to the display inside the car.
Andy.
MichaelH
Re: Temp. reading
Same problem but no reading at all....So come on folks, how do you remove the mirror without breaking it?
I've got photochromic glass which need a mortgage to replace.
(answers please for either Xenton's 2001 C5 1, or my 2008 C5 3)
UK Midlands currently with C5 (X7) Exclusive 2.0 HDI + 2 Pug 306s (Meridian and L) and a Pug 206L a/c
Previous C5 1 Exclusive 2.0 HDI, Pug 407LX HDI, 2No. Pug 406s LX HDI, Pug 309GLD, Pug 205GL, Pug 505GL, Pug 604SE, Pug 504ti
oneday
Re: Temp. reading
i know on the mk1 and 2 you can buy the painted plastic part of the mirror so you must be able to remove that to gain access to the temp probe not sure about the 2008 model
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- x 5675
Re: Temp. reading
There is a description somewhere and the glass does have to come out but it isn't that difficult (allegedly).
I think it is that, if you look carefully beyond the edge of the mirror there are a pair of wire clips visible (at the top, IIRC) and with a suitable implement these clips are moved toward one another, releasing the glass (which then falls to the ground and breaks, no doubt
- x 3565
Re: Temp. reading
For the C5(X7) you're supposed to tilt the mirror downwards, force the glass outwards from the top with a blunt tool (plastic spatula type arrangement), and unclip the 8 fixing lugs. The service manual doesn't say anything about picking up the now broken bits of glass
Replacing the C5(X7) temp sensor is a simple cut the wires and crimp in new ones affair - after first switching off the ignition and waiting 3 minutes before disconnecting the battery, according to the service manual......
spider
- x 77
Re: Temp. reading
If you're lucky the wiring to the element (if heated mirrors) will stop it falling to the ground.
A simple alternative: Stick a piece of masking tape to the mirror outer housing and the glass, leave about 3 or 4 inches 'slack' in the middle so you can carry on working. It should catch it if it tried to make a break (no pun intended I think) for freedom.
Andy.
xenton
Re: Temp. reading
I should also of mentioned if I set my CC to 27 it blows hot and 26 and below blows cold, I'm guessing this goes of an internal sensor, could the two problems together indicate a fault else where.
Mark D.
