306 injector
froggy
- (Donor 2026)
- x 4
306 injector
Hi, my wife"s, 306 , 1.4 petrol. it started to miss quite badly. I have changed the coil pack, it has made no differance. plug leads are ok. could it be the injectors? if so , is this a garage only job? many thanks inadvance , Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
spider
- x 77
Re: 306 injector
What year 306 is it ?
, Its the only one in your signature without a year
Very late models (the 'phase 3' from V plate I think) were multipoint. Earlier models were usually (but not always) monopoint injection.
Is the 'K' light on ?
Are spark plugs OK ? (whip them out and have a look) if its not running on one cylinder or running barely on it the difference in the plug condition will show.
The injectors do come out of the rail without too much trauma if I remember correctly. I'd be tempted to check its not plugs (or leads if its an early model, later ones have the coil pack sat above the plugs) at fault first
I the warning light is not on which would be unusual as I'd expect it to make an appearance if there was a misfire if nothing else the emission level would be amiss in most cases.
Andy.
froggy
- (Donor 2026)
- x 4
Re: 306 injector
Hi, its a 2000, model. The plugs and leads are ok. there is no warning light on. cheers.
Terry
froggy
- (Donor 2026)
- x 4
Re: 306 injector
Diagnostic check is saying injector 2 and 4 faulty! I guess I need to atempt to replace both. is it easy?
Terry
addo
- Sara Watson's Stalker
- x 95
froggy
- (Donor 2026)
- x 4
Re: 306 injector
Drove the car this morning, it drives fine, when cold, but as soon as it gets to temperature, it starts to miss badly, does this confirm injectors?, Terry .
Terry
addo
- x 95
froggy
- (Donor 2026)
- x 4
Re: 306 injector
What is a CAS? SORRY FOR SOUDING THICK. Terry
Terry
addo
- x 95
Crank Angle Sensor
http://www.auto-essentials.co.uk/ecomm/ ... -2830.html" onclick="window.open(this.href);return false;
It's below the thermostat housing, embedded into the bellhousing top. The dummies test for this, is when the engine's misfiring you stop the motor, and pour a cup of cold water on the sensor, then restart. If it runs smoothly again the sensor's internal windings are broken.
froggy
- (Donor 2026)
- x 4
Re: 306 injector
any chance of a picture in situ ? cheers Terry .
Terry
spider
- x 77
Re: 306 injector
I'm unable to find a pic via google search for you
If I remember correctly, its a browish plug with three wires into it. The brown one "IN" the thermostat housing is not it, that's the bitron sensor for A/C in most cases.
You should see something with maybe a greyish cable and a black or dark grey body sat "inside" the top of the gearbox.
Look below the top hose under the thermostat as indicated above.
Andy.
