Xantia - CANISTER DEPOLLUTION ABSORBER
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
Where is the CANISTER DEPOLLUTION ABSORBER located ?
Regards
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
addo
Sara Watson's Stalker
x 94
Unread post by addo »
Here:
See the black "bottle"?
lancia58
(Donor 2022)
x 8
Re: Xantia - CANISTER DEPOLLUTION ABSORBER
Thanks Addo . So in order to replace it I need to remove the L/H from wheel arch protector and the L/H headlight ? Any precautions ?
addo
x 94
Nothing to worry about for removal, however if you have a fault with the depollution canister electrovalve this is not the faulty item - it is the brown cylinder above the LH headlight.
lancia58
(Donor 2022)
x 8
I just got a new depollution canister out of eBay for $15 my car mak year is 2000 so just decided to replace it. BTW how can you verfiy that the electrovalve is OK ? I use the Lexia and can hear the clicking , Is hearing the clicking indicates the electrovalve is OK ?
Regards
Zohar
addo
x 94
$15! You're lucky.
The Lexia test clicking indicates your electrovalve is working normally.
