Citroen C5 1.6 HDI engine problems
jeyjey1982
Unread post by jeyjey1982 »
Hey guys, I have 2005 c5 1.6, engine broken, crank shaft is bent, costing fortune to repair, I wonder is Peugeot engine has same brackets, and all stuff exact same as my citroen? I'm looking for second hand engine now, thanks :oops:
Citroenmad
x 110
Re: Citroen C5 1.6 HDI engine problems
Unread post by Citroenmad »
Yes, a 1.6HDi from a Peugeot should be a match for a replacement. It might be an idea to check engine codes out of certaintly.
What caused the engine to break? Snapped camblet or something else?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
jeyjey1982
number 4 cylinder holder on crankshaft broke the bolts, for no reason, it was serviced 5000 kilometers ago, and had full dealership history
jeyjey1982
It started to make ticking noise, and disappeared again, so I went like 10 mile, and started again, and in few minutes time engine stopped, now I have my engine nearly on the ground, by look from underneath, it looks cheaper way is to get new engine, i think everything in engine will be bent and scratched and.......
jeyjey1982
jeyjey1982
Can be crankshaft reconditioned?
Xantidote
x 4
Unread post by Xantidote »
Sorry I've no knowledge of the C5 or the 1.6 engine, but FWIW my inital thoughts would be not to even consider trying to recondition the crankshaft. If it's bent, surely best to ditch it?
Question is, what other damage has been done, and how/why it happened. There have been other posts on the forum about the 1.6 engine really needing regular oil changes.
As per your initial post, looking for a replacement sounds a good option
Martin
1995 Xantia TDLX (deceased :( )
Lighty
x 34
Unread post by Lighty »
I have fitted the PSA engine from a Ford Focus into a Picasso, all brackets matched etc, massive amount of work though.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
jeyjey1982
Hi guys, thank you for replies, con-rod bolts broke off in cylinder no.4 for some reason, I've bought that car few months ago, had serviced about 3000 miles ago, everything by the book, main dealers was servicing before that, friend said, maybe some time it was very low on oil, but I don't know, Ill go in to engineers and they will measure crankshaft, will see from there, maybe will be need to buy new engine for it, and its expensive, thank you
Xantidote
x 4
Well, good luck with sorting the engine. If you go down the repair route, then let's hope there's not too much other engine damage.
Martin
jeyjey1982
I've engine from Focus, looks the same, will see how ill get on :) Does anyone knows do I need to reprogram injectors, because on the other cars need? :?
cc101
Unread post by cc101 »
Hi, yes you'll have to program injectors unless you use your old ones and put them in the same order.
Chris.
Xantia 1.9 TD 1993 (sinker)
jeyjey1982
Car is back on the road :)
Xantidote
x 4
Well done jeyjey - hope it doesn't give you any more trouble
Martin
jeyjey1982
Xantidote wrote:Well done jeyjey - hope it doesn't give you any more trouble
Thanks I hope so too, its expensive thing to repair them :)
