Because I have to take my Berlingo out onto the road to save upsetting my neighbours at the moment to work on it, I need to do what I need to do it fast - I need to get pads and discs for it (the set I had weren't right!). How can I tell whether it's the Lucas or Bosch system? Does it say on it in an obvious place somewhere?
cheers
Mike
Stupid Question..
- x 94
Re: Stupid Question..
if you send me the last 8 digits of your chassis/VIN No. i will check on service citroen
Regards, malcolm.
Northern_Mike
Thanks ever so much.. you have a PM..citronut wrote:if you send me the last 8 digits of your chassis/VIN No. i will check on service citroen
addo
- Sara Watson's Stalker
- x 95
Northern_Mike
Re:
Yeah, I know. I just didn't want to take it all apart, then put it back together while I wait for the bits to arrive! My neighbours would complain.... these are neighbours who try so hard to avoid me at the moment that rather than ask for a jump start this morning for his VW P!sshat, he bump-started it IN REVERSE.. it sounded painful.addo wrote:The other giveaway is pad shape, each pad type is unique in some way. Look at ears, antirattle springs, tabs on the top, all that sort of stuff.
- x 94
pm'ed also
here is what listed for your chassis No.
BOSCH
EXCEPT SUSPENSION AND WHEELS 1000KG
A) + 4407 19(1)
01
4246 W1
RP 4249 G1
FRONT DISKS KIT
DIAM 266 EP 22
02
4400 R6
CALIPER CYL
LEFT
4400 R7
RIGHT
4410 67
RECOND CYLINDER
LEFT
AV
4410 68
RIGHT
AV
03
4253 42
RP 4254 75
4 BRAKE PADS/F
SEE A
LVX L10 0 6
M:4 FR BR PADS
- AND AGE >= 4
i still havent got the knack of copying drawings over from service citroen as yet
BOSCH
A) + 4407 19(1)
01
4246 W1
RP 4249 G1
FRONT DISKS KIT
DIAM 266 EP 22
02
4400 R6
CALIPER CYL
LEFT
4400 R7
RIGHT
4410 67
RECOND CYLINDER
LEFT
AV
4410 68
RIGHT
AV
03
4253 42
RP 4254 75
4 BRAKE PADS/F
SEE A
LVX L10 0 6
M:4 FR BR PADS
- AND AGE >= 4
Regards, malcolm.
