Hello My first post. My Berlingos lower brake lights seem to have stopped working. The high level light is ok. Its the two in the light clusters.
I have checked the fuses. Bulbs are ok. Has any one got experience of this.
Berlingo Multispace brake lights 2006
- New User
Re: Berlingo Multispace brake lights 2006
get 4 meters of 17 amp cable £3.79 (halfords) and 2 block connectors .break into the blue wire on the connector on the switch above the brake peddle . reconnect them adding one end of you new cable .run the new cable under the fuse box and down the side of the trim . no need to take it off just ease it in using a flat screw driver . run the cable along to the back door post loosen the trim on the back post pull it forward then feed the cable through the bulk head to the rear light . break into the brown wire and reconnect with the extra cable job done takes about 20 mins . hope this is useful charlie .
