I replaced my brake valve and my back spheres (3x) and now the car is "spongy"! Suspension and brake's. I let the air out at the back brakes and at the accumulator (screw). Is it possible that the screw (with plastic ring) at the brake valve is also to let the air out ??
Xantia 2.0 8v 1994
please let me know!
air xantia
JohnD
- x 72
loe hofmans
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>
Have you tried going from high to low on the suspension several times, with a pause in between each movement?
yes I did, but i'm also driving with the problems for almost 2 weeks
I did drive 12 years bx and xantia so I realy know a lot about the car but this is new for me
Thanks for the reply maybe you can help me
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
JohnD
- x 72
Sorry - I haven't an answer. Post your problem on http://www.members4.boardhost.com/citroen_bx There are some very knowledgeable guys who can probably give you an answer.
