My 94 Xantia TD has developed a knocking noise localised to the front passenger side wheel area. The knocking noise frequency increases with road speed, however disappears on acceleration, and reappears when i back off. It also disappears under braking.
Do these symptoms ring any bells?
Thanks,
RT
knock noise from xantia front
Dave Burns
What about when you go round a corner, does it get worse in one direction that the other.
Is it a constant knock when it appears or is it a bit hit and miss.
I would have said it was a goosed wheel bearing and it probably is, the doubt if any comes about when you say it dissapears under breaking, thats a bit odd beacuse braking ought to produce the noise too since the loadings on the bearings will be similar to those when you back off.
If you can feel any play in the wheel then that nails it, but play and noisey bearings don't necessarily coincide, especially in the early stages of bearing failure.
Dave
Dave
wrinklet1
