Synergie air con problem
SkyWelder
Hi folks, Noticed the if I turn the air con on in Citroen Synergie 2.0 HDi the air coolant light flashes on the dashboard just replaced temp sensor for new one. any ideas why this is happening or a solution? SkyWelder
BX
- x 19
Re: Synergie air con problem
The cooling fan low speed is probably not working. The fan (the one on the radiator) should run at low speed when the air con is activated.
