Can any one confirm if a elm 327 blue tooth obd2 adapter using to torque pro will connect to a picasso 2001 18 16v ?
Want to buy one but cant find anything that say says it is supported.
ELM 327 BLUE TOOTH
cc101
Re: ELM 327 BLUE TOOTH
Hi, you'll be able to read basic information like engine temp/rpm, but not codes, obd2 was introduced on petrol 2002. I've got an elm327 and torque pro, great with compatible cars.
Chris.
Chris.
Xantia 1.9 TD 1993 (sinker)
bamba
thought obd2 compliant was introduced January 2001, deisel 2004
cc101
I normally say to people 2002 to be on the safe side as I've tried it in a couple of 02 scenics without success, but you are right in saying 2001 as 2001 was the cross over year.
Chris.
Chris.
