Xantia–Help Interchangeabililty of pressure regulators
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
Does anyone know what are the differences between the various circuit breakers ? Externally they look the same. On my car ( Xantia 2.0 16v Automatic hatchback , make year 2000 ) the Citroen part number is 527419. Do they vary between the different engine types ? Do all of them regulate the same pressure ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 94
Re: Xantia – differences between various pressure regulator
Unread post by citronut »
here is a listed for some MK1
95 574 618
CIRCUIT BREAKER
- BVM AND BVM BE3 EXCEPT INJECTION XU10J4R
5274 11
- INJECTION XU10J4R AND BVM AND BVM BE3
5274 10
NFP
- BVM AND BVM ML5T
96 172 847
NFP
AR
- BVA
although i think the last one is for the rear end
and here is a list for some M2
95 574 618
CIRCUIT BREAKER
- INJECTION XU5JP
- INJECTION XU7JB
- INJECTION XU7JP
- INJECTION XU7JP4
- TURBO DIESEL XUD9TE
- DIESEL TURBO XUD9SD
- TURBO DIESEL DW10TD
5274 11
- INJECTION XU10J4R
Regards, malcolm.
lancia58
(Donor 2022)
x 8
Xantia–Interchangeabililty of pressure regulators
Are they interchangeable for instance is the 574616 interchangeable with the 574619 ? If not what are the differences ? Is it only different bracketing ?
Zohar
handyman
Re: Xantia–Help Interchangeabililty of pressure regulators
Unread post by handyman »
Same block, different spring pressures so affecting the regulated pressure. You can fit different ones to your car but it will change characteristics of the system.
H
lancia58
(Donor 2022)
x 8
Hi
Is there a way to know the characteristics of 575616 in compare with the 574619 ? BTW what is the reason for the diffrent spring pressure ?
Zohar
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
With some pressure regulators the overflow outlet is at a different angle so worth checking that out.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
lancia58
(Donor 2022)
x 8
Can the outlet be detached from the regulator ? Can the outlet be swapped between regulators ?
Zohar
