ABS light not coming on... MOT fail!
ed4ferrets
Hi just wondering if anyone has had this problem where the ABS self test light does not illuminate?
Also on a Xantia S2 '99 model at what stage should the light come on i.e. before (ignition on) or after engine has started?
cheers
ed
cheers
ed
Ed
'63 Renault Caravelle - stored
'99 Xantia 1.9TD Estate - matrix done:))
JohnD
- x 72
Re: ABS light not coming on... MOT fail!
It should come on with the ignition switch and go off after the engine has started.ed4ferrets wrote: at what stage should the light come on i.e. before (ignition on) or after engine has started?
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
jgra1
- (Donor 2021)
- x 36
check the bulb ed?
andmcit
- x 30
Yep, just because it's not coming on doesn't mean someone has removed the bulb to hide the fact the
system is in trouble! Recently my Xm didn't show a light which got an MOT fail and it turned out to be
a duff bulb. That's not to say there may be more hidden by the missing warning light.
Nothing moves you like a Citroën
ed4ferrets
ah yes I meant to say the first thing I did was check the bulb.. hoping that was the problem but sadly the bulb is good!
Ed
- x 94
the car does have ABS fitted i suppose
my 98 MK1 TD estate does not have ABS so the light fails to come in
Regards, malcolm.
andmcit
- x 30
There's no power in the circuit at all which is odd as the point of the warning light is to cut to indicate
the system is in fail safe in such an event. Like Malcolm says, it is supposed to be fitted with ABS! lol
ed4ferrets
also checked the ABS fuse which according to BOL is fuse number 6.
sadly the fuse is in excellent health so the mystery deepens further
unfortunately the situation is URGENT as I need to MOT, insure and tax the car in order to drive to Scotland at sparrow fart on Wednesday
Ed
Mandrake
- x 694
What happens if you unplug the big connector to the ABS ECU ? Normally that would trigger the ABS warning light to come on permanently, from memory...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
ed4ferrets
Simon assuming it did go on would the light then go out again when plugging the connector back in? Don't want to exchange one problem for another for mot purposes
Ed
Mandrake
- x 694
The point of unplugging it is to try to test the wiring to the light, as the light should come on if the ABS ECU is not working.
Another question is, does the ABS actually work ? If you brake hard, (somewhere where it's safe of course) do you feel the brakes pulsing or do the wheels just lock up ?
At the moment we don't know if we just have a fault with the indicator light or wiring or whether the ABS is completely non functional.
If there is a forum member nearby with a Lexia it might be worth your while getting it tested on that as not only will that test and talk to the ABS ECU, it should have a way to manually operate the warning light.
Simon
1978 CX 2400
1978 CX 2400
DickieG
- Monaco's youngest playboy
- x 38
Yes Lexia does have the facility to test the ABS light.Mandrake wrote:If there is a forum member nearby with a Lexia it might be worth your while getting it tested on that as not only will that test and talk to the ABS ECU, it should have a way to manually operate the warning light.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 94
i think if the ABS fuse was blown the lamp will light to indicate a fault,
my X boss had this on a BX we fitted a new fuse on that car it was No. 14, and the light operated as it should,
till weeks later after an emergency stop when it popped the fuse again, obviously a fault in the ABS unit caused the fuse to blow,
you still have not said if you are sure your car has ABS
Regards, malcolm.
ed4ferrets
Simon, how ironic... I'm sat here trying to sort this lot out in order to get to Scotland and you're sat in Scotland exactly at my destination COATBRIDGE
Ed
ed4ferrets
...and YES the car does have ABS for those who were wondering
Ed
